Are you sure it has no molybdenum? Cause the tests on it show fairly high levels of it. Especially compared to Liqui-Moly.
Look at the line with the molybdenum ppm in the test sheet attached under the heading with 85,000 miles. This is Castrol. That is about the same amount as Shell Rotella T-6!
I read
your thread here and *hoped* the Castrol 5w-40 Synthetic 4T Motorcycle Oil was going to the same as I could not find an MSDS on it specifically when I bought the oil off Amazon:
https://www.bmwsporttouring.com/top...m/topic/93431-experience-experimenting-with-oil/?do=findComment&comment=1030847
In this thread you stated "Sample date of 9/1/2019 is the most recent. Castrol Racing 4T 10-40", and the BS report stated moly level of 2ppm. But this isn't the same oil anyway it would appear.
But beyond all of this I think there is reason to believe there is a bit of market manipulation going on by BMW in this regard, specifically $18.98 per liter's worth on Amazon! I read that entire thread and that is the impression I came away with. Clearly people with wet heads are running Castrol 5w-40 4T Syn Moto oil and aren't chiming in with stories of early demise, and this of course supports the conspiracy theory developed in the above mentioned thread. And in the example you just provided from David, he's got over 85K miles on his 2015 RT and has had the similar levels of moly
in all of his blackstone tests and their comment says wear levels are hunky dory at 85K+ miles. Clearly no one here, or maybe anywhere, can state with any conviction what amount of moly, and what specific formulation of moly, might do in your engine coatings.
Anyway, thanks for pointing this out, be it relevant or not is anyone's guess. If I notice poorer shifting on this first trial of using Castrol I will switch back to LM which was fine, as was the Adv Ultimate I used up until my last change done w/ LM. But I'll be shocked if there is any perceivable difference in shifting when using the oil meeting the same wt, API/JASO rating as the oil I've been using I just see no way, no mechanism, for that to happen beyond subjective nocebo. LM certainly made no difference in anything perceivable over Advantec Ultimate, but I've read people's comments who think otherwise. I'll find out soon hopefully when the snow/ice clears from my egress.
Much ado about a conspiracy...
https://www.bmwsporttouring.com/top...m/topic/93431-experience-experimenting-with-oil/?do=findComment&comment=1031347
And apparently BMW Advantec Ultimate has double or triple the moly that Castrol 4T Syn Motorcycle Oil has. Oil threads ya gotta love em :
https://www.bmwsporttouring.com/top...m/topic/93431-experience-experimenting-with-oil/?do=findComment&comment=1032495
