Hello, I'm new here. My 2010 RT just 10k miles and it have Brake Failure light on about month. I had google about the brake failure solution ( check front and rear sensor wires, brake light, changed brake pads and changed fluid both side) and has done all but the brake failure light still on. The brake failure light on when I start ride about 5 miles away from home when arrived my company I park there 8 hours and when I turn on the key to return home the brake failure light flashes like normal but when the bike run about 5 miles the brake failure light on again and stay there until I arrived home. And the brake failure light start to on after the bike run 5-6 miles everyday. I use GS 911 check the fault code and it showed (24048/24049 Power supply to motor fault and 24052 Electrical system under voltage). Could anyone experienced with this problems? Thanks
