Programming Key Fob
27K views 31 replies 24 participants last post by  OregonRider
#1 ·
I recently purchased a backup key fob for my new ' 16 R1200RT. Surprise, surprise, when I picked it up, I discovered it was not paired to my motorcycle. Dealership wanted $52 to program the fob. There's a fast and easy technique I performed to program it myself.
Step1. Remove GPS. Not required, but makes this process very easy.
Step 2. Start you motorcycle. For you primary fob is damaged, start bike with wallet key by placing wallet key blade in the gap at top of instrument panel cluster and area of the bottom right corner of GPS.
Step 3. With engine running, wedge new fob in gap at top of instrument cluster and area of lower right corner of GPS.
Step 4. Press and hold the BMW roundel logo on fob until you hear the bags lock.
You're done. You will now be able to lock/unlock and start the bike with your newly programmed fob.
#3 ·
#5 ·
It's my guess that because the RT and K bikes have the same instrument cluster, it would be the same location for the RfID antenna and therefore these instructions should apply. The best way to know would be to place your wallet key in the bike in the area described, without your primary fob in the area, and see if you can start your bike. If bike starts, follow the instructions above from this article. If your GT does not start with your wallet key, then you will need to first figure out where your RfID antenna is located, then follow the instructions in this article.
Use your wallet key to home in on your RfID if it requires searching out.
Good Luck, and please advise if the instructions did or did not work for your GT so that others may know.
#7 ·
Yes. If you are thinking of your alarm remote, then I believe that the instruction for programming any extra remote is in your rider's manual.
#8 · (Edited)
Brilliant Post!
I just used your info to program my new spare fob for my '16 R1200RT. Mine was only slightly different in that I do not have central locking, therefore did not have the locking of the bags as a signal of programming success.
I brought the original radio fob into proximity to start the bike. I then removed the fob from proximity of the bike, which causes the yellow key/question mark caution light to illuminate on the warning panel. I then placed the new fob on the top ledge of the instrument panel (below GPS mount) and pressed the roundel. Within a few seconds the yellow key/question mark caution light disappeared, signaling completed programming of the new fob. Just to be certain, I shut down the engine and panel and then restarted with newly programmed fob. Success!
#11 ·
I know this thread is a year old but I'm finding the FOB I just bought has the same problem as the previous poster. I'm unable to get the key/? symbol to go bye bye. I do not have a central locking system but not sure that should matter. Has anyone run into the same issue and resolved it? I have the right speaker removed for easy access to the panel.
#12 ·
I had the same issue and was never able to get the fob to accept the programming. I ended taking it to the dealer and they programmed it during a scheduled service. I did ask what what they did to get it programmed and the tech mentioned that he had to remove the windshield??? I would think by removing the speaker that you are essentially accomplishing the same thing. BTW they didn't charge me to program it.
#14 ·
Your US prices are still better than here in Canada. I recently paid Cdn$240 plus tax(about US$190) for a second key fob for my 2016 RT. The new fob came with a directions for pairing with the bike but I ran into the same problem as recent posters and couldn't successfully pair the new fob. I ended up going back to the dealer and was quoted 1 hour at $110/hour to do the pairing. I ended up going to a second dealer who did it for about half that amount.
#15 ·
Resolved. Again, this is for a 2016 RTW. A clue was provided in the reply that said the dealer had removed the windshield. I did that, which revealed two torx and two Philips screws to the back of the instrument panel housing. It doesn't need to be removed (something was preventing that, anyhow) but it did loosen the plastic up a lot. The lame instructions that came with the FOB indicated of tolerance of only 2" from antenna ring.
I was able to lift the nav cover high enough to provide lots of room to insert my new FOB. See the attached pictures.
1. Remove the windscreen.
2. Remove the four screws to the back of the instrument panel (2 Torx-6 and 2 Philips)
3. Start the engine with your original FOB.
4. Relocate the original FOB out of antenna range (mine was 8' away)
5. Lift the nav panel
6. Insert the new FOB back into that space, then press and hold the BMW button. It took, oh, 4 or 5 seconds for the ?key indicator to go out.
7. Stop the engine and turn off the bike.
8. I waited a good 30 seconds or more before turning it back on. And tried several times to actually believe that it worked.
Maybe a 15 minute job.
Stu
#16 ·
Who would of thought it would take all that to program the fob? I'm glad it worked for you.
#18 · (Edited)
Hi
Here is what I had to do when programming the Key fob.
I tried to do what MonzieRT showed in his video, but I couldn't get it to work.
2. Remove the Cover for windsreen adjuster, and locate the Ring antenna.
3. Put the Key fob in the middle of the Ring antenna and push the ignition button. When the igition come on, the Key fob is programmed.
#28 ·
The plastic key can't be reprogrammed! It has just a simple built-in chip that has to be customized to your bike.
#31 ·
Wow. What a PITA.
I never realized that I NEEDED a second key (which didn't come with the bike when I purchased it second-hand) until I inadvertently lost my key on the floor of a buddy's car - then couldn't find it days later, as I was about to leave on a 4-day weekend tour to Lake Placid. Lost my hotel deposit. Didn't make the trip. My buddy did, though. My key was found AFTER they returned from the trip :-(.
So - I dutifully ordered a spare key from BMW, which arrived a couple of weeks later (COURIERED from the factory in Germany, no less).
Researching / programming the sonofabitch took hours, because most of the so-called instructions on the interweb were short on some of the REALLY IMPORTANT DETAILS. Lots of stuff on GS's. Not the same. Lots of stuff on programming the plastic key with the chip but no battery. Not the same. Argghhh!
Here's what finally worked for me (thanks for the MOSTLY correct instructions in this thread):
0. It ain't in the user manual, so don't waste your time looking there.
1. Start your bike (using your good key).
2. Move your good key far, FAR away - so that the yellow "key absent" indicator on the instrument panel starts flashing.
3. With your GPS NOT mounted, place your replacement key near / below the lower right corner of the GPS mount. I think having the key over the gap between the GPS mount and the instrument panel may help; of course, the gap between the GPS mount and the instrument panel is too skinny to fully inset the key between them, so just play with it
4. Press and hold the round lock button on your key, until the key absent warning stops flashing. This may take a couple of tries; don't give up!
5. That's it! Once the "key absent" warning light goes out, your new key is programmed!
6. Turn off your bike, then test your new key by turning it back on again. With the bike turned off, try the central locking and unlocking buttons on your new key to confirm that they're working as well.
Order has returned to the universe...
