'14 RT - Cruise Control a little 'lurchy'
1 reading
1.5K views 11 replies 10 participants last post by  Dan_rt
#1 ·
There is one long 50MPH construction zone on the interstate here that they are enforcing pretty aggressively, and I have been using the CC on my '14 to lock it in at or under 50MPH. But when going 50 or slower, there is a slightly perceptiable 'lurching' when the CC is engaged. I assume this is the computer working to keep the speed rock solid, but it is a little detracting. At 75 MPH it is a non-issue.
It's not big deal, and I just kill the CC if it is bugging me, but I was curious if others have noticed this at all.
#6 ·
Only time I notice it is when I am going downhill and the cruise control keeps switching from accelerating to decelerating. Has to be the right grade to do it though.
Having said that my cruise control switch is playing up and the resume works only sometimes. Due to be replaced next service.
#12 · (Edited)
When I did the test ride on my 07 RT I did notice that the resume button wouldn't work.
I was able to use cruise control until the first time I disengaged it by using throttle, brakes or clutch and then, when hitting the resume button, nothing happened. The cruise control did not work at all until I switched off the engine and start again, but cruise control would only work once, until the first time it was disengaged, with no possibility to resume.
Took it back to the dealer's and they replaced a wire that was causing the problem.
