Hi to all !!
Has any body installed the Zumo 550 output to the auxiliary input of the LT 2005 ?
How does it work ?
I would like to know if the audio level on the speakers is the same as the CD player.
Thank you !!
Just purchased a 550 today and fired it up on my 05. Plugged the Zumo into the aux. plug on my Voice Com II and at first the volume from the Zumo was quite a bit lower than the standard radio. Reconfigured both voume controls on the Zumo and all is fine now. Wish I could say the same for the phone workings. Having a few troubles trying to get the mic working through the VC.
Has anyone used the XM feature on the 550? Is it direct wire only or can it use the FM radio like the XM Roady?
Assume you have a GXM30 XM radio and active subscription that plugs into the Zumo? If you've got that, the Zumo outputs XM on it's wireless or wired outputs.
