Another question! What is the yellow wire connected to my positive terminal connect to? It goes into the wiring harness left side after going thru an inline fuse? I took out the fuse and everything still seems to work? Radio, NAV II, IPod (replaced cd changer with DICE unit), CD, Aux, lights, dash, etc.
Something added by the previous owner. Pull the fuse and see what no longer works!
Discussion Starter · #3 ·
I did! Everything still works!
It's goto go somewhere...which direction does it head front or back? Extra power socket somewhere, extra lights in rear, trailer wiring, ground effect lights?
Discussion Starter · #5 ·
It seems to go forward. I'll have to take off the Tupperware and see if I can trace it down. I now think it went to an XM sat that used to be on the bike. Duh! I forgot it used to be on there! I took it off since it never worked. It was a factory install I think it was in the odd box but would never even turn on this is why I at first didn't think the yellow wire was to this as the wire to this was a black one. Have to take of the skin to be sure. A job for some other time when I have to open her up anyway. Maybe this winter. Anyway Thanks! I just wanted to be sure it wasn't something on everyone's bike that needed to be powered up. The bike only had 6K and the guy I got it from didn't add anything to it. He got it with 3K on it two years ago. I've put about 2k in last 2 months so far.
