HI All,,
VERRRRY long story short... I am replacing the right hand swicth gear on my UK spec 1999 K1200LT.
The previous owner had an alarm fitted, this was removed by the garage I bought the bike from as it was defective.
On removing the old switch gear, I have found two wires in the main 'bundle' to the switch have been cut and taped (brown and brown/black)....and another pair that have been run up from the relay box under the fuel tank. These have been soldered into the main switch gear, but I have been un able to get the switch gear apart to see what they solder to.
OK... fitted the switch gear...every thing works...EXCEPT The starter button!
With the ignition on, every thing primes as it should... If I now touch the end of the two wires that have been run up from the relay box together, BINGO... the bike starts.
So.. I am guessing the extra pair have been used to bypass something... any ideas how I get round this?
If I splice them into the wires from the starter button....what colour wires feed the starter button?
HELP!!! Pulling my hair out with this now!
