Here we go some more. I hate to be a pest......but. I need some help with the left handlebar multifunction switch wiring. I am trying to hardwire a Garmin power supply inside the left handlebar cover. I have the Garmin power box located and tied to the handlebar and it clears everything and the covers fit. I am trying to decipher the wiring diagram and am not having fun. Here is what I have to work with and what I have traced out so far using the Clymer wiring diagram for a 2000 model:
green/white tracer------------------?
green/brown tracer----------------?
green/blue tracer (small)----------?
blue/yellow tracer-------------------?
blue/brown tracer-------------------?
yellow/green tracer-----------------?
yellow/brown tracer----------------?
gray/yellow tracer-------------------?
purple/green tracer-----------------?
brown----------------------------------ground
brown/white tracer------------------?
brown/ yellow tracer----------------?
white (large)-------------------------headlight high beam
white/yellow tracer (large)-------headlight low beam
green/blue tracer (large))--------power from fuse 6 fuse box 2?
I am assuming that I can use the brown for a ground and I am guessing that the larger green/blue is fed by the load shed relay. Am I thinking correctly or are there other options? I would like to keep all wiring under the left handlebar covers.
Thanks, Robert.
Thanks, Robert.
