1 - 2 of 2 Posts
HELLLLPPPP,
Hi people,
I replaced the wire harness on my 1999 k1200lt. I got everything hooked up.........but one connector. It is the connector by the fuel injector rail. it is the connector with the green and white/green wires. Where does that go????
I also found a wire that comes from the very rear, it splits into 2 connectors 2 black wires in separate plugs and a brown that goes from one connector to the other (about 2" brown)
Thanks in advance,
Rob
HELLLLPPPP,
Hi people,
Thanks in advance,
Rob
My guess is it is for the fuel vapor recovery purge valve. Mine has a rubber plug over the end but yours may have the hose attached that goes to the charcoal canister if it is still on the bike. Otherwise, the valve will be plugged or the hose will be plugged somewhere further back.
1 - 2 of 2 Posts
