1 - 14 of 14 Posts
First, this is my first post although I have spent countless hours reading forum since I purchased my 99 Lt last April and have clocked a little over 7k miles (73,262). She has been well maintained with fd replaced, brake lines, tires, Clutch/master cylinder and regular fluids when I purchased her. Yesterday, I put her in the man cave for winter upgrades. It was a sad moment but she will be fresh and ready for the trips that we have planned next year.
Here are my plans and upgrades on her along with few questions:
1. Change all fluids-easy
2. Change the weak battery-suggestions on type?
3. Install battery tender
4. Install hid to replace current headlights(I have the PIAA lights so I will go with just a low beam 6000k)
5. New windshield-cee cee windshield reverse contour 20" I am 5'10"
6. Install usb charger under my shelf for gps or iPhone
7. Replace broken windshield bracket-(I bought windshield motor and brackets unit on eBay so I don't have to machine it.)
8. Install two ram mounts for electronics-shelf and brake mounts
9. Replace most of the Tupperware screws-any idea where to purchase these without going to bmw dealer 2.00 a piece....ouch!
10. Examine steering dampener- I watched video
11. Front brake lines are metal, rear is a new oem part. Not sure why previous owner did not replace all of them got to figure this one out.
12. I might tackle brown wire fix. I had a few issues last summer when it was hot.
13. Maybe speedo adjustment not high on list
14. A thorough cleaning top to bottom.
Wish list
1. Sargent day long seat upgrade
2. Replace dash cover where fuel lid is. A little scratched and marred.
3. Highway pegs
4. Better riding gear-aerostich suit with heated vest/pants to extend riding season
5. Bluetooth headsets for me and wife(with a great mute button just in case she wants to be a backseat driver!)
Here is something that puzzled me...after my last ride a week ago I noticed a lot of brake dust material on rear rim. I should have taken picture. I'd never seen that before and bike was clean. Any ideas?
Please feel free to add suggestions because this is my first winter break with her and I have a lot miles planned for next year. I am in eastern nc going to the Keys on Easter break, and possibly california and back this summer or at least to the Rockies along with multiple blue ridge weekend trips.
Shift linkage should be cleaned and lubed also. Make sure it's all tight and working good.
The stock organic pads in the rear are very dusty. I am running semi sintered on an EBC rotor. Much less dust.
Not sure if that year has a charcoal cannister but I recommend ditching that if it is still on the bike.
Currently using a Odessey PC680 with one of their chargers.
Go and try on some Klim gear. I'm using their Badlands jacket and Adventure pants. Both are full Gortex and having owned Vanson, Olympia and Teiz nothing fits better on me and and offers that kind of protection. Not cheap but it is something you will own for a long time. Sena makes a good BT set up. I was losing the channels on the stereo so i stripped out and replaced with 12v USB chargers and plenty of room left over. Consider a fuze box if additional electronics are in your future. I'm in Greenville,SC so drop a line if you will be this way. Touring Sport is the local BMW dealer and Thomas McCord is their GM and a great guy. Welcome to the club. Hope you enjoy your rig as much as I have mine.
The PIAA lights are a plus, but not enough to compete with HID upgrades. When I first installed HID low beam, I saw minimal improvement in light coverage. I have since added HID high beam and love it. The 6000k HID is getting rather blue. In my opinion, the 4300K or 5000K is a better choice...much whiter. Went with the DDM Tuning HID kits.
For highway pegs, I enjoy the Mik-O-Pegs.
Battery Tender Jr. works well for me.
Speedo adjustment is irrelevant if you are using a GPS.
Dump the stock springs and replace them with Hyper Pros. Make sure to rent their spring compressor, the best $20 you'll spend.
Discussion Starter #8 (Edited)
I just wanted to say thanks. It makes me want to ride "Camille" more and more every time that I log on. I will be starting my maintenance this weekend and hopefully finish before Christmas(advantage of being in in education that I have 2 weeks off during Christmas).
I have tried on Klim badlands jacket last weekend and I will have to save up for the mortgage on that....lol I am looking an aerostich suit for some reason.
Need to check rear pads and that eased my concerns on something major.
I will look into charcoal canister....I forgot about that.
I only put premium in gas tank and I need to investigate air sensor and correct that. It could be a problem on long trip this summer.
I want to change springs because I think the rear spring is almost shot but don't know how to exactly tell.
Scratch brown wire! Good info.
Definitely change to hid headlights ...great info.
Basically saying screw speedo but I will take chances on blue light bandit.
I have removed radio because of obvious bmw radio issues. I did not think of using the left over electronics to create a electronics center in "glove box".
I have done 7k miles since April and my goal is 10k in 2015. Best experience on two wheels with my bmw. BTW, I have owned a 97 hd fat boy and 03 HD ultra. I love the LT best bike by far especially 2up!
Thanks for info and I am planning on keeping camille even if I decide to buy a small gs or k100 as a run about bike.
While you're stripping the tupperware and changing coolant, consider replacing the coolant hoses--all of them. IIRC there are 5 all together including the overflow hose. And the thermostat.
You will be amazed the improvement on engine response and hesitation unpluging the air temperature sensor can make during a hot summer. I installed a switch on mine so as to be able to disconnect the temp sensor during summer and reconnected it back during winter but it turned out that the bike runs fine with the temp sensor disconnected even during cold winter.
I really dont care much of the speed indicator being unaccurate as I have a GPS that gives me exact speed.
Not sure if your model came with the heated seat. Mine did not and that was an easy upgrade I did later which was really worth as I ride all year long. I bought a used LT heated seat on ebay and installed it on my bike and wired it through a relay.
I completed the service and upgrades on my bike. Going through the service history on my bike, in 2004, the fuel disconnects were replaced. So I figured everything was good. However, when I took everything apart I noticed that they were plastic. So I ordered the metal quick connects from Beemer Boneyard just for peace of mind. I was lucky and living on very borrowed time. When I took the first male connector off, I was examining it and snap it broke off in my hand from being brittle. So I went ahead and replaced all the lines and fuel filter inside the tank. Maybe the best money spent then to the HID upgrade.
I did not order Cee Cee Bailey windshield. I polished my OEM shield with headlight restorer and it took some of haze off. I don't look through it anyway but it looks better on bike.
I took it out last weekend and a 70 degree for a 150 mile shake down. I was nervous because I am not a mechanic but a business teacher by trade. However, she was flawless and really got me pumped for some weekenders!
Then the weather in Eastern NC turns into the Polar Express...Depressing!
Thanks to everyone for sharing their knowledge on this board and the videos online because I had a lot of fun working on my bike. Now I need to learn more about electronics and how they work.(My new passion for knowledge.)
Trying to decide if I am going to make plunge on Russell Seats....
Hey, great job. Glad to hear you got it all done and back together. I know it is a great feeling to do that work yourself and be able to ride with pride knowing you saved a lot of money.
I second the Charcoal canister removal. And the shift linkage clean and lube. If you have GPS. That will give correct speed. I didn't bother with the speedo fix.
I did the speedo fix on my 2003 (unfortunately there is no way to calibrate the '05). It was a PITA, but I was so glad I did it. Mentally calculating the 10% over all the time was annoying. Toughest part was getting the cluster out. The fix is just soldering a little piece of wire across two sets of pads on the back of the speedo but you better have a magnifier...they are tiny - or maybe it is just my old eyes.
1 - 14 of 14 Posts
