Looks like my relays are getting intermittent. Took it all apart today and tested the relays on a multimeter and all looked fine. Put them back in and everything worked as it should, so I put it all back together. Now it is slow again, so probably burnt contacts that can't pass the current.
The question is....
Where do I find replacements in the UK? They seem an unusual design.
Can you post a pic of the terminals on the base, also any part nos. on them.
simoncharles said:
Woolly, you been away ?
Been a bit busy (becoming an orphan) over the last two years, but now back with a vengeance :) - check out THIS thread!!
Thanks for that both, I will have a word in the morning. If they are SPCO they will do the job.
Just spoken to Motorworks and the relay in the illustration referred to above is not the right one.
The correct part is ELA93415 which is a grey 5 pin SPCO plug in relay. Application list is K75, K100LT and K1200LT.
Cost is £10.18 each.
