It is usually the relay that fails. It has an up relay and a down relay. I helps to lube the arms now and then to help keep the amp. draw down.headhanso said:My wind shield adjuster worked intermittently and then failed completed. The fuse is okay, is it usually the relay that fails or the adjuster motor. The bike is an 05 K1200LT
