1 - 9 of 9 Posts
Fueled up and stupid me spills petrol on the r/h wind deflector , so does anybody out there knows how to remove the stain without damaging the plastic .
regards numbnuts in blighty
I would start with some plastic scratch polish paste, if that does not remove the craze on the surface ... likely your going to be Shi* outa luck :(
You may try cleaning the surface with denatured alcohol and then polish with PLEXUS.
I had a stained, cloudy screen. I used methylated spirits and that cleaned it up a treat. That was about three months ago and I have not had the cloudyness return :dance:
Translation according to Wikipedia:
Denatured alcohol is used as a solvent and as fuel for spirit burners and camping stoves. It is also known as methylated spirits
Loren
Just don't drink it Loren :p
Mothers makes plastic cleaner and polish you can use with the foam ball on a drill, can be found at WalMart or local auto parts store.
There's been a rise in thar over here. Mixing it with orange or pineapple juice to take the edge off.
That and the alcohol wipe sachets at A&E (ER) at hospitals.
1 - 9 of 9 Posts
