I installed a new fuel filter when I installed new shocks. Plus I changed all of the fluids and removed the canister.
I've remounted the tank. With no key in the ignition, when I connect the two prong plug at the bottom rear of the tank, on the brake lever side, I hear a whuring sound.
I don't know where the sound is coming from since I disconnect the plug and jack when the noise starts.
If it makes any difference, the white plug at the top of the gas tank was connected.
Any suggestions?
When I turn the ignition on I get the normal sounds; when I hit the starter key, the starter kicks in.
Many Thanks
Bob
Make sure you haven't mistakenly connected the fuel pump connector to the spare powerlet connector hanging in the same area. Believe it or not, they fit. How do I know this?
Bob
Unfortunately, i can confirm what Bob says.
Of couse i didnt do it myself, i just know a man who did!!!!.
Regards
Stevie
That was it.
Many thanks
Bob
