Hit my rear brake today and nothing -no pressure on pedal
Any thoughts? Cant see any leaks anywhere.
No Bike BIO .... What year ?
Bill, you had not had the rear pads out for any reason had you? Replacing them maybe? If so, you will get nothing until the pistons push back out to where the pads are contacting the rotor. Of course it should only take a pump or two. If you're saying that you can't get any pressure that is a problem.
Symptom... no rear brake and full travel of foot petal..
Need more information. :confused:
Do you have the normal ABS light sequence at startup. i.e. turn the key on and it flashes back and forth. ??
Thanks guys I found the problem.Worn brake line from the adapter block to the rear caliper.It is in the only crook in the line just like the speedometer sensor wire Right above the banjo fitting.
Guys this should be one of the things you check when you do your checks.Could be dangerous.I know I went to brake pretty fast and no pedal.
