I have the following in progress, and I need to know if I am missing anything....
2001 LT, 19815 miles.
Fluid changes- oil, anti-freeze, final drive, transmission, brake fluid flush.
Fuel & oil filter
New spark plugs (NGK)
2005 throttle cable mod
PIAA 1100x install
Modulating brake light
HID high/low beam
Lower fork bridge ball joint boot replacement
Steering dampener overhaul
Radiator fins back wash
Rear EBC disc
Rear EBC HH pads
Disconnected airbox sensor
Reposition top box aft, for passenger comfort
Speedometer correction mod
Dash lights changed to red LED
Serviced aft shock preload
Removed factory antenna, replaced with hidden amplified antenna
Connected jumper wire to add rear center running light to brake lights
Canisterectomy
I know some of this may seem like overkill, or premature, however, I just bought this K12 last month, and I want to know where she stands...
I do have new QDs in the future, along with the weep hole mod, just not this time.
Thanks for the input!
Fuel & oil filter
PIAA 1100x install
HID high/low beam
Rear EBC disc
Rear EBC HH pads
Canisterectomy
