Hi Gang,
I'm going to rewire the Autocom (and some other stuff) on my 2005 LT. I would like the Autocom and the other stuff to come on at the ACC position on the key (first click, when the radio comes on) and not ignition like it is now. Is there a convenient place to tap ACC power? I will probably drive a relay with it and supply the load directly from the battery, so current is not a problem.
I spend time in ferry lanes and would like to talk with the pillion without having the headlight and all on!
-Scurrie
DaveDragon said:
The rear seat heater plug is a good source.
Nope, that is where it is connected now, and that doesn't come on until the key is in the ignition position.
I guess it is easy enough to tap right at the fuse block, at the radio fuse (#4), and wire that to my relay.
-Scurrie
