Hi all
I have just bought a garmin zumo and have been wondering where the best place is to mount it.
Cheers Hovis
where you don't have to take your eyes too far from the road......................
mounted my 2720 on a copilot shelf right in the middle (bottom) of the windscreen
IBR# 366
Up high and centered, usually on some sort of a shelf. Don't want to have to look way down while riding.
I mounted my Iway 500 right above my radio controls. I'm sure you can set up the Zumo the same way with the right Ram mount.
I took about the front tupperware and radio off. I pryed off the BMW roundel that was right ontop of the radio display. I then drilled the hole for the mount. I mad it slightly oversized for the wires to squeeze in.
I ran the power right to the battery. The audio is stored for now under the driver's seat until I can afford to buy the audio cable from Raffy to my Baehr intercom.
I wish I could take credit for the idea but I copied another board member who posted their directions here on the board. If you use the search feature, I'm sure you'll find it.
Good Luck!
Click on any of the links below this post and you will get additional ideas and pics. Then go the Accessories and Gear forum, GPS subforum, and do a search on GPS mount. All kinds of pics showing shelf mounts, handlebar mounts, RAM mounts, etc.
