1 - 9 of 9 Posts
Getting ready to take a look at what appears to be a rear tranny seal leak. Aside from a 30mm socket with a window cut into it and a 12mm allen cut-in-two (that I of course do not have) what other tools am I gonna need to procure?
Seems to be a plethora of seal leaks and/or clutch failures going on. Maybe it is just that I am more tuned in to these issues now that I am facing one myself.
There is a good write-up in the technical document files for Slave-Weep hole drilling that lists the tools needed. (I did not write it,just posted it) You will be right there so it's a good time to drill that weep hole.
I can mail you the socket and wrench and drill bit if you like.
Dan Martin
Also if you want a walk through video you can down load the three Weep Hole videos in the sticky at the top of the page. You will need a sturdy 14mm socket to pull the swing arm pivots.
It might be that these things are starting to get a little "long in the tooth". The 99's will be celebrating their 13th birthday this year.
Loren
Could be, Loren, but my current LT is an '05 with about 30k on the clock.
I wonder if there have been any chemical changes to the lubricants manufactured in the last few years that may be interacting with the seal materials used in the LT? Just a thought..
My 05 developed a rear output shaft seal leak @18K that was repaired under warranty. I have not replaced a single seal since but did have the engine output shaft o-ring weep a little oil on my worn out clutch @50K. I really believe I did it slipping the clutch too much when pulling a trailer cross country. I changed my methods then but I need another 25K to be sure the new technique is saving the clutch.
Just watched the videos, Thanks John. Takes the mystique out of it but definately requires me to invest in a few more tools.
Dan, Awesome, thanks. Look for my pm. Let me know how much you spend on shipping and I will return that with the tools.:wave
BTW, mine is an '05 with only 24k on the clock. I am wondering if all these seals were made at the same time in '99 or earlier?
1 - 9 of 9 Posts
