What size Torx Wrench is reqired to remove the oil drain plug?
Thanks, 150flyer
hey 150Flyer...
I don't know what kinch has but my 2005RT does not use a Torx for the Oil Drain plug and it is not behind any cover plate.
It is actually an 8mm Hex.
What else?
2010 RT uses an 8mm hex. :D
Most everything else on this bike uses a Torx so I just assumed. I tried an 8mm hex and it fit perfectly.
Thanks, 150flyer
skydiver said:
My 2010 RT takes a Gold Visa card at the dealers (one of these days I will have time to do this, but for now the Visa is the easiest tool to use).
There are oddities to every bike .. I learned the hard way that my previous tool (AMEX) was incompatible at the dealer I went to. Luckily I had a tool similar to yours as a backup otherwise I'd have been stuck. :bmw:
