1 - 3 of 3 Posts
Ok, I have stripped the LT down to the frame. Here are the things I will be doing while it is apart.
Oil Change
Fuel Filter
Install K and N airfilter
Fuel Filter
Rear drive fluid
Install hi beam hid
fix the autocomm wiring. Fuse holder is broken.
Is there anything else I really should do while she is naked? I also plan on cleaning all of the tupperware inside and out.
The LT has 18000 miles on it.
Oil Change
Fuel Filter
Fuel Filter
Rear drive fluid
Install hi beam hid
If you don't already have 'em, put metal fuel line quick disconnects on while you have the tank off. Compressed-air clean the radiators, blow from the backside. Do the cannisterectomy and install a Thomas 215 air compressor in it's place, with a coil air hose that'll reach to the front wheel (HOW search will turn up some good info on this mod, by David Shealey and others).
Have way much fun - butt don't take 8 months like me!!!! :rotf:
1 - 3 of 3 Posts
