It is a connector with green/white and green/blue. That is the tank vent valve. Often confused with the injector connectors with the green/white and yellow/green wires.
Is this a US bike only connector,I have the same plug but not connected to anything, currently strapped to the injector rail???
that connector is not used on the European bikes my 02 is the same
Pulse valve most likely. Used to scavenge the vapor from the charcoal canister on US-spec bikes.
Someone has removed your Charcoal vapor collector and repiped it to just hose to a low area. A common mod and often done when the canister becomes fuel logged due to overfilling the tank once too often.
