No experience with the alarm system other than people disabling it after having trouble.Hey Gordon,
Thanks for this, I believe the coolant has to be nitrate and phosphate free for the aluminum engine.
Burp process, not familiar with that.
I also see where this bike has an alarm and central lock but it never came with a fob. They must have disengaged the alarm somehow. Do you know if fob's are programmable to these bikes?
Thanks again for your help.
This works for me. Looked like new after four years, just as the OEM did after four years, but much less expensive.Now that the bike is stripped I figure it is a good time to change all of the fluids including coolant as I'm not sure when the last time it was done on this bike.
Any suggestions as to what to use?
If Evans was as all pro and no con as their web site suggests, everybody would use it. Everybody doesn't. There usually is a reason. Might want to read this before switching. This comes from a competitor so that needs to be considered, but you can find several other sources that discuss the many downsides of Evans in addition to the cost downside. I like this one as it is very thorough and tested using ASTM standards.Evans waterless, have ity in 4 cars 3 bikes, never needs changing. Jay Leno uses it in all his old and new rides.
Best ever 375 Deg boiling, never corrosion, no H2O at all!
