Didn't plug the GPS in. Didn't ride the bike.charlieg said:Could you have left the GPS on? Did you ride the bike during the three days, or did it just sit? -Chuck-
Ammeters are a mistery to me (as were relays a few months back)Woolly said:There's nothing wrong with the circuit diagram. When you get a new battery, use an ammeter to check each of the connections into the -ve DB to find where the leak is.
I was thinking bout measuring the current flowing (switch multimeter to 200m (about 4 o-clock) on dial, then proceed exactly as above) rather than voltage, but either way, there should not be any voltage or current flowing when the ignition is turned off.DanMartin said:Voltmeter: 2 leads...red into right side V*MA,black into COM
Switch to 20 at about 10 o-clock on dial
!. Disconnect all wires at Neg. Dist. Box.
2. With all switches off.
3. Black lead to neg on battery
4. Touch red lead to each wire you disconnected,all should read 0.0
5. Any reading other than 0 is your leak
dan
No problems shortening the wires - the shorter the better, just make sure they're not strained and leave yourself enough room for maintenance, removal etc. Make sure the connectors are properly fastened, especially on the higher current ones to the lights - if you have a bad connection on these, they can get very hot, and possibly start a firec00k1e said:Know of any good sites that talk more about the black art of Voltmeters?
Last Q - some of ther wires (the lighting ones mainly), are extreamly long. They were sets for a car. If I was to shorten the wires, is that a problem?
This will either blow the fuse in the meter, if it has one, or will damage the meter. Current is measured in series with the load, not across it, voltage is measured across the load. And I would use the high current scale on the meter anyway, just in case. If you want to see if current is flowing when all the new accessories are off (shouldn't be any), plug the red test lead into the meter "10ADC" hole, black test lead in the "COM" hole, set the meter to 10A at the 4:30 position. Now, disconnect the negative lead going to the battery from the "neg distribution box", connect the red test lead to this wire and the black test lead to the battery where you disconnected the wire, the load will now go through the meter. The meter should read 0.0 if everything is off. You can now measure how many amps all this stuff is drawing by turning it all on, however, if the lights are more than 10A (which they are if they are driving lights, which is why you used relays), you will blow the fuse in the meter. Leave the lights off. If you measure current with everything off, you have something wired wrong. Disconnect things one at a time until you see the meter go to 0.0. Follow the wires, figure out what you did wrong.Woolly said:I was thinking bout measuring the current flowing (switch multimeter to 200m (about 4 o-clock) on dial, then proceed exactly as above) rather than voltage, but either way, there should not be any voltage or current flowing when the ignition is turned off.
cfell said:Hey C00Kie,
Ride on by Saturday morning and we'll snuff that bug.
If you can't make it, I understand.. Good luck!
