referring to my previous posts complaining that the suspension of my 2008 Lt is soft for my likes, i tried to increase tire pressure more than what the manual recommends.
So i put 38psi front and 45psi at the rear and went for a ride.....WHAT A DIFFERENCE!!!!
My bike has changed ALOT!!!
I was a bit afraid to put more pressure but now i want to hear more from you...
What pressure is "safe" to run and what else do you recommend?
When I bought my last LT (Grey Goose), the guy complained that the bike rode like crap. He sold it to me DIRT CHEAP. Tire pressure was at 12 lbs on the front, and 18 lbs on the rear. I aired the tires, and drove it home (950 miles). She drove like a dream, a great dream! It pays to check the tires!
I've always been grateful for this site. Seemingly good kind people trying to help each other without condescending or ulterior motives. I hope thats not changing. 42-48 will give your more miles as well.
The cycle manufacturers have to balance handling, tire life, etc. when they set their recommendations for pressure. Just keep in mind that the max pressures listed on the sidewall are what's important. The manufacturer has no control over what vehicle their tire gets mounted on, so tires are rated by max load at max pressure cold. They are designed to gain pressure as they warm up on the road. Generally, running the max pressure will give you the longest tire life as well. I run 45 front and 50 rear all the time.
Tire pressure
This is what I've learned thru talking to the tire manufactures. Use the "10%" rule.
Start at 42 front and 42 rear, which is stamped on the Avons, go for a "normal" ride, enough to get the tires up to temp. When you stop, check the pressures immediately. You should have raised the pressures by 10%. If you are low % you have too much air, too high % too low. Add or lose a little and try again the next day. You would be surprised how much difference 1 or 2 lbs can make. Worked for me for the last 25 yrs. the first 15 I was just a baby biker still learning,and almost all brands of tires on different bikes.
You could run nitrogen as it is rated for both winter and summer.
44.8K members
