You put too much in? I have the old style reservoirs. Could be the rubber seal is bad.
I had the same thing happen. I cleaned debris from under the seal grove and replaced the seal for the cover. Still ended up seeping out. Was told by the BMW technician that this is normal if you fill it to max level or just above. When the reservoir is tilted to one side or another it will seep out. Keep the level below "MAX" when the reservoir is level or close enough. If it still seeps lower it a small amount again. This solved my problem.
[/QUOTE
thanks. I’ll try that.
I had same result on my 2007 RT. Dealer suggested might need new master cylinder, but removing a small amount of fluid did the trick.I had the same thing happen. I cleaned debris from under the seal grove and replaced the seal for the cover. Still ended up seeping out. Was told by the BMW technician that this is normal if you fill it to max level or just above. When the reservoir is tilted to one side or another it will seep out. Keep the level below "MAX" when the reservoir is level or close enough. If it still seeps lower it a small amount again. This solved my problem.
A dealer that suggests the most expensive solution. Hmmm. How odd.I had same result on my 2007 RT. Dealer suggested might need new master cylinder, but removing a small amount of fluid did the trick.
