Good one Kirk, Thanks.
Yes, another good video. If you pull the coil out, you have better access to the sensor and you don't have to drain the coolant. Just put your finger over the hole as you pull out the old sensor. As long as your radiator cap is good and in place, almost no fluid will leak out. The spec for tightening that sensor is 30 Nm or 22 Ft lbs if you can get a wrench on it.
Reactions: 14wntr
