1 - 3 of 3 Posts
I ride a 06 K1200LT. It only has 10000 miles on it and I recently developed water leak that now seems like I has changed to oil. It only leaks after I return from a ride. My thoughts are this is related to the water/oil pump. Wondering if any one has experienced this before.
put up a photo of the area that is leaking, is it engine oil or transmission oil?, unless you can give more precise information every one will be guessing most likely.
The lower hose of the water pump can emit water cooling system at the clamp. We need details of your problem.
1 - 3 of 3 Posts
