So I've had the bike about 3 months and this morning at 5am I was riding to work it was a little cold so I clicked on the grip warmers and after a few minutes I felt my throttle hand get nice and warm, however my left hand was still getting a cold. I gave it a few more minutes to see if it would fire up but nothing.
When I got to work, I slowly lifted up the grip and to my surprise I found there is no heat element wrapped around the left handlebar, just black plastic. I see a silver wire that looks like it was broken stuffed under the grip.
So here's the question. Do I need to replace the entire assembly or is there is a replacement heater element I can buy?
Miles of Smiles
Unusual to just have one side installed I would think, unless removed by previous owner...
The heating wire can break or more likely burn through in a hot spot.
Repairable with care.
Really need to peel back the grip to see what's happening.
To your original question.
LHS Part number for heating element. 61317694811 (Just confirm)
OEM or Max to check part numbers.
Cheers and enjoy the site.
So I removed the grip and it looks like the entire heater element has been stripped off.. dammit.
I appreciate the part number. Will this part # get me the heater element and a new grip? How would I go about removing the old one and installing the new one?
Miles of Smiles
That's just the heater element. The grips are another part.
I haven't replaced mine as such, just repaired. IIRC it requires quite
a bit of tupperware removal as you need to feed the leads down through
the handle bars to the connector. As you have them installed already,
not sure if it's possible to just solder to existing leads.
Check eBay or Beemer Boneyard for a used grip heater, unless of course you just want brand new and can handle the sticker shock. If you need a new grip rubber you can replace both sides with part number 32 72 2 332 620. It is actually a grip for another model BMW but fits both sides of the K1200LT and is much cheaper than the K1200LT original part. Once installed you really won't see much of a difference and I have found that this grip rubber has lasted much longer than my original grips.
To install the new grip rubber you first remove the old by very carefully cutting off the old grip (sharp knife, great patience) starting from the end closest to the center of the bike, then peeling it away. You must not cut down into the heating element or damage the element while peeling away the old rubber which will be slightly stuck to the heating element.
Once the old rubber is off and the area is gently cleaned (time to install your replacement heating element and run the wire) you need to prepare the new grips. If you bought the part number I recommended you will first need to strip the rubber off of a plastic insert that comes with that particular part. Once stripped off, I applied a bit of contact adhesive to the inside of the grip then slid the grip into place, checked that the rubber was seated all the way down then let it sit and cure for 48 hours. I've tried using silicone/RTV but it eventually released and having a throttle grip spin in your hand while riding can be a bit of a problem.
The cheapest fix for replacing the grip rubber is to buy a set of Grip Puppies that slip over the existing rubber. This also increases the outer diameter of the grip which may feel better to you and adds a bit of extra cushioning.
Good luck!
+1 on the Grip Puppies. I have them on my 02 and love them. They increase the diameter on the grip but the heat works well with them.
Another nod for the Grip Puppies. I have been using them since I got my bike and really like them. Not too often do I need to turn on my grip heaters but you still feel them with the Grip Puppies.
