1 - 2 of 2 Posts
Hi,I have had a warning triange light come on the dash over the last few days, checked all the bulbs and levels, all seem fine.The hydraulic centre stand motor seems to be running after the bike has fully engaged it and is fully up ,any one had anything like this
If only the triangle is on that means the center bulb is burned out. That bulb has only the low wattage filiment used and the warning is a trow back to the RS which uses the same ABS unit and has only one tailight bulb. Just replace the center bulb and the fault will clear.
1 - 2 of 2 Posts
