Interesting since that's how I took them off, crazy.Nice job on the retrofit. When time permits flipped those hold down plates 180 degrees as from my understanding they are on upside down. Even some of BMW’s promotional videos have then on upside down and even seen one case where one was each way.
Hmm. Not too sure about the newer models but my '15 has the wider part to the top, just like Motor32 shows in his video. I've never seen them with the narrower part of the plate to the top. ¯\(?)/¯Nice job on the retrofit. When time permits flip those hold down plates 180 degrees as from my understanding they are on upside down. Even some of BMW’s promotional videos have them on upside down and even seen one case where one was each way.
If you google 2022 R1250RT and pull up the imagines of which there is a hundred or more nearly all of them show the narrower part at the top. All 3 dealers in MN are mounting them with the large part inward on the bottom. I’m not suggesting I’m right just passing along my experience.Hmm. Not too sure about the newer models but my '15 has the wider part to the top, just like Motor32 shows in his video. I've never seen them with the narrower part of the plate to the top. ¯\(?)/¯
I know look in the service manual, oh I forgot you can't get one for the new RTs.If you google 2022 R1250RT and pull up the imagines of which there is a hundred or more nearly all of them show the narrower part at the top. All 3 dealers in MN are mounting them with the large part inward on the bottom. I’m not suggesting I’m right just passing along my experience.
Sorry to change this thread away from the reconfigured screen so hopefully back to Motorhead 32 topic of post.
That's a great id..--- wait, what service manual would that be ----------- ????I know look in the service manual, oh I forgot you can't get one for the new RTs.![]()
No, it drilled like butter.@Motor32, great job retrofitting. Your frugality is commendable. Any trouble drilling the plastic?
This first photo I posted of my bike, @darrell PMd me because my covers were also upside-down (I think it is officially a crusade now). Turns out that when you turn them around, they do follow the lines of the windshield mounts better. Had to do the same thing with the rear shocks on my Harley... the factory (or dealer) put those on upside-down as well. Another reason why the next bike was a BMW.
Good to know. I've drilled windshields before (not for this bike) that caught and cracked. Destroyed the whole thing.No, it drilled like butter.
Just start small and slow and it was all good. Here's the link for the drills I used.Good to know. I've drilled windshields before (not for this bike) that caught and cracked. Destroyed the whole thing.
If you have polishing equipment and compounds, along with some experience, you can remove about any scratch or swirl from the Quiet Ride screens.......I'd love a new screen as my old one is scratched. Shipping and excessive USD to AUD makes it nearly a $500 screen!!
Ill wait.
Yep. Step drill bits are what they're called, and they are awesome for plastic. They'll even chamfer the edge a bit for you. Didn't take long to learn that a $40 step drill bit costs less than the thing you just destroyed.Do NOT use a standard drill bit you would use to drill metal!!! The easiest to use are the single cutting edge drills like the pine cone shaped step drills. These are best also because you sometimes need a fairly large hole.
I had to walk out to the garage and check but my '23 has wider part at the bottom.If you google 2022 R1250RT and pull up the imagines of which there is a hundred or more nearly all of them show the narrower part at the top. All 3 dealers in MN are mounting them with the large part inward on the bottom. I’m not suggesting I’m right just passing along my experience.
