· Registered
:confused: i have a 2005 LT and this past weekend i had a vapor lock happen on the fuel system. when i opened the gas cap, i had alot of air rushing into the tank. pulled my phone out and did a quick search and found in the hall of wisdom some talk about vapor can clugging up... so i pulled the trunk off on the side of the road and removed it... still no luck, can't start it... long story short, had to have it towed home.... what would be a good start to look for???? any help would be good....
thanks for your inputs....
· Registered
Did you plug the injector side of the hose when removing the canister?
· Registered
Discussion Starter · #3 ·
Yes i did plug the other side with threaded bolt.... it seems like it's not getting fuel, but i hear the fuel pump working....
what other problems can happen i need to look for.... i really don't want to take it to the dealer....
Thanks for you reply...
