2000 K1200LT, 74,000 miles. My first time checking, PO had it done 25K ago. So.. all the intakes are tight.. all the exhaust are loose!
Intake tight meaning, some will take a 4/1000 (.101mm) feeler gauge, some will take a 5/1000 (.127mm) feeler gauge.
Exhaust loose meaning, they will all take a 12/1000 (.305mm).
Hear are my thoughts.. The intake shims need to be loosened by 1 shim size (.05mm). The exhaust can be tightened by 1 shim size (.05mm). So I just swap intake and exhaust shim cam followers! Net result is the exhaust get tighter and the intakes get looser.
Anyone see the same wear over time (intake valves tighten/exhaust valves loosen)?
