1 - 11 of 11 Posts
Oh boy, I hope there is a good answer to this predicament I'm in. While removing the cam sprockets I realize that the cam chain tensioner is not released. So I go ahead and replace the one tappet bucket that I need and now i can't get the cam chain tensioner to go down in order to replace the sprockets. I can get it to go down slightly, but not near enough to place both sprockets on their cam ends. Anyone else ever have this problem? I really don't want to pull the timing cover if not necessary. Any and all advise is appreciated. Steve
What morley said...AND, be patient....it can be done, no problem, just take your time when doing it and double check the alignment marks upon reassembly. It'll just take more time and patience.
As others have said, patience. The piston will not go down fast, as there is only a very small hole to allow oil to escape when you push down on the tensioner. You have to force the oil out through that small hole, so it takes a little time holding pressure on it to allow the piston to be pushed back into the cylinder. I CANNOT be done fast.
Well, after two hours of constant pressure, it has not budged. Is it possible that the piston in the tensioner has come out of its bore? I have a floor jack holding the end of my large screwdriver so my arms don't look like a lobster. Took a nap thinking I'd come downstairs and find that I needed to adjust the pressure on the driver. No go. Any thoughts? Steve
Hope it didn't come apart on you. Is it maybe all the way down now? Can you insert the 1/8" drill bit/ pin?
Steve, you say here that you can't get both of the sprockets on both cams. Does this mean that you are able to get one sprocket on one of them? If so, you may be able to carefully take the open end wrench to that cam which has the sprocket attached (and aligned with the pin in it's slot?) and apply some torque to the cam in the direction which would give you some slack between the cam sprockets. You may be able to get the other sprocket on then. Just a possibility.
I'm concerned that if the piston has come out of the tensioner, it may not be in place to go back in. Yes, I can get one sprocket on, but he other is about an inch away from alignment. I'm hoping someone can tell me if the piston can come out, and if so, is the only answer to pull the timing cover??
Steve
From what I'm reading in the shop manual, it shouldn't be able to "come apart". It is all held together with "E" clips and the slide on type metal retainers. Check your chain and make sure it isn't hung up on something or "kinked" (one link doubled over another).
That's potential good news. I decided to give it a rest and go back through each step. In the event that I simply can not get the chain loose enough i will simply invest another day into the front timing cover. i was planning on changing the coolant anyway.
I really love the feeling of accomplishment when you get this beast back together and it starts right up. As has been said in many posts "once you do it for the first time and make your mistakes...".
Thanks for the replies!
Steve
1 - 11 of 11 Posts
