Rashou812 said:Check out "part 13" in this list and you'll see that BMW calls it a "Grub Screw".
http://www.ascycles.com/Illustrated...=Single_parts,_clutch_fitting&bindCat=32_0929
its also call the same on the brake side.. "part 18"
http://www.ascycles.com/Illustrated..._parts,_parking_brake_fitting&bindCat=32_0930
I guess that my point is that you cant speed shift it at low RPMs..
OK fair enough the parts list calls it a grub screw but that is usually a term BMW uses for the little cover screw on the bleed port on the clutch line. The BMW manual calls it an adjusting screw.
Shift linkage maintenance is always a good thing as the ball studs come loose they will snap off.
