1 - 20 of 24 Posts
I love my '02 K1200 but can't figure out what is causing the "squirrely" ride when we ride two-up. I have tried different air pressures in my Metlzlers, different rear shock adjustments and don't know what else to try.
I will explain as best I can the "squirrely-ness". When starting from a dead stop it feels as if the rear end is drifting to one side like I have a low tire. Once up to speed I seem to have trouble holding a line and the bike seems to yaw and roll. I usually ride with the windscreen in it's lowest position but raising it makes it worse. I am sure it's either a problem with my specific bike (or me) because I am certain these are not normal characteristics of a BMW.
It just seems like I am fighting the bike for the entire ride and that's no fun. My GF has even commented that the K doesn't seem as stable as our Valkyrie Interstate....and that just shouldn't be right.
Here are some answers in advance:
K has less than 19k on it
I don't drink and ride (anymore)
My GF is five-foot nothing and a hundred and nothing
No extra loading in the side/rear cases
I had the FD checked at the 18k service and all was good
Metzlers almost new and in good shape
If anyone has experienced anything like this or have any suggestions as to how to correct this I would surely appreciate it.
Hi,
It sounds as if there is sometihing wrong with the frame.
If you bought the bike second hand, are you sure it was never damaged in an accident?
bruno
Bought from reputable BMW dealer on consignment who had sold the bike new to the original owner. They had all the service records and the bike had a clean Carfax. I asked the owner (retired Detroit City Motorman), the salesperson and the BMW mechanic and they all said no wrecks (other than tipover) or major issues. I seriously doubt they would all lie just to sell one consignment bike. It's possible, but I doubt it. They had plenty of other bikes they could have sold me.
I appreciate your suggestion and will have another mechanic ride and evaluate the bike when I get it back to Detroit this weekend. I want to keep this bike but have to feel good about riding it....especially two-up. We have long ride plans this spring and want to take it if I can get this issue resolved.
Thanks again.
The first few miles I rode my LT it felt wobbly and unstable unlike my other BMW's. I think she is very responsive to any input on the bars and I keep my arms completely relaxed - it's possible you have a mechanical problem but have you tried putting the cruise on and tried just resting your fingers on the grips no pressure to see if it behaves any differently. With finger tips on the bars you can grab them pretty quick if you need to.
There was a tall parabellum windshield on mine when I bought it and it was terrible in any crosswind until I put stock back on, big sail.
Reactions: copperstatetour
I would say get another dealer to check every bearing, swing armfd pivot, and front and rear fd bearing again. Maybe the fd preload is like factory spec, No Good!
Reactions: rugguy
Sounds like it's headed to the dealership when I get back. Thanks.
I would start by asking the dealer to lift the bike and ensure that both wheels spin smoothly. If the front brakes are not fully releasing I think you might experience something like what you are describing.
Then I would mark a parking lot or the tires and roll/ride the bike in a straight line and see if the tires are lined up.
That's where I would start.
Put it on the center stand and grip the rear wheel at 3 and 9 o'clock positions and check for side-side play.
There shouldn't be any.
Weight the back of the bike so the front tire lifts off the ground and repeat shake on the front wheel.
No definitely not normal. The only time I really felt "squirreley" was when I had serviced the pre-load adjuster and got interrupted and left it on it's minimal setting. We went for a ride and I felt it, stopped, cranked it back to where it was and all was normal again. Strong winds can also give the feeling. Look at the motorcycle and there's no where for a cross wind to pass through.
You've already got some great suggestions there. My $.02 worth:
The only times I've experienced this condition are:
1. When I rode with a flat rear tire, two-up. (long story)
2. When the final drive was toast. I made the mistake of riding it home, knowing the condition it was in. Even though I rode gently and took back roads, every throttle or brake input was an exciting experience. The bike was all over the place.
I'd have someone other than a dealer check the final drive. There are too many stories of dealer technicians not knowing what to look for. (sorry...) Several guys on this site can do that, if it comes to that.
I'm going to second Gary on this test, be careful but you should try it, you might be used to having to provide 'positive influence' on your Valkyrie whereas the LT needs little more than your thought to guide it. I know after riding my R1200C for a while and then hopping on the LT after a hiatus I have to dial back my control inputs because it is so much more responsive.
Heavy wind will cause it to feel squirrely as noted elsewhere and I assume that you have adequately tested the various preload positions since you mentioned that, perhaps you should check and if needed refill the pre-load adjuster. Do a site search for it and you will find the document, also one of our members has a bunch of videos and one of them covers it I think. Takes about 5 minutes and makes a huge difference if you're low.
All that said, check those metzlers for cupping or uneven wear as that might cause it, they may be in good shape with good tread but if the edges are scalloped that can cause a whole bunch of stuff. Some of the highways around here are concrete paving with rain channels cut in that run the direction of travel, when I get on one of those it's always a wild ride as I think the guy you scored them in was one hand on the wheel, the other on the Jack Daniel's.
If none of these things solve it, then you do have a problem that probably should be rectified. I would think a bent frame or the like would manifest in other areas of the bike as well like the space between panels not being even/equal etc.
I once ordered new Metzlers from a non-BMW dealership and I distinctly specified that they needed to be VR rated to handle the weight. The tires arrived at the dealership and I brought my bike to them. 30 minutes later I was riding off on a new set of treads. While the new tires felt smooth and much more quiet than my old ones, I did notice that they were 'squirrely'. When I got home, I looked closely at the new tires and found that they were not the correct Metzlers that I had specified.
If you are riding on the new 888's they need to be the 'reinforced' version. If you have the old 880's they should be VR rated.
Lastly, Metzlers absolutely hate tar snakes on the road. I'm not really sure where you are located, but if the road is covered with tar snakes to seal up cracks, you will experience 'squirrely' handling no matter what time of the year it is.
Reactions: Axle
incorrect tyre load rating for the bike,
Definitely something wrong somewhere. The LT is normally rock steady, Good luck with your issue.
Chiming in,
I'm going with the tire "rating" suggestion.
Make sure the tires, especially the rear, are correct.
AND Please check the torque of the rear wheel bolts before you ride again!
I've had a non weight rated rear tire on my LT. Was on a trip in the middle of nowhere and rear was showing chords. Anyway. Had no choice but to put a Dunlop on to finish the trip to get home. The Lt was rock solid. I can think of a few things.. Bolts on rear rim aren't torqued properly. Check your final drive as stated. Check the pivot bolts are torqued proper on the swing arm. Does your rear tire have flat spot in the middle/cupped ,Underinflated?.Unless like suggested. Your not used to the LT's side wind manners. I know it took me awhile to get used to it in crosswinds and to stop overcorrecting it. The suspension is completely different from my Intruder LC.:cool:
Is your 5-foot nothing GF leaning out to one side to see around you?
Even though she doesn't weigh much, any movement or off axis position she takes will make an input to the LT with its high cg.
The higher cg of the LT is also why the Valk might feel more stable in comparison. The low cg and longer steering rake of my 1100 Shadow makes the LT seem "twitchy" in comparison.
Also check your tires for defects. Even though they are near new, that doesn't preclude them from being defective. Simply put the bike on the centerstand and check for run-out, both radial and axial.
I have one teenage son who cannot sit still. He has had one very short ride on the back of my LT. Only pillion that has made me worry about dumping the bike. Of course his being 6'5" and 250lbs might have something to do with that too.;)
1 - 20 of 24 Posts
