1 - 9 of 9 Posts
I was cleaning my '03 today and was wondering what kind of jacks anyone uses to get the girl up? I have a Craftsman motorcycle jack that I use on my VTX however it appears it just won't work on the LT.
Also, I noticed the rear brake rotor is a little "loose".....rattles a bit when I wiggle it. The bike just turned 30,000 miles. Is this common on this bike?
Thanks.
Ride Safe.
Thanks Morley...is the loose rotor anyhting to be worried about?
Hi bandit
plenty of threads on rotors just use the search feature, I would never say it is nothing to worry about, but it will get worse until the rattle drives you nuts like it did to me at 30.000km and I replaced it. very easy to change you might want to consider a non bmw replacement though. Merry Xmas to you all from OZ :bmw:
Howdy, Bandit.
The LT can be safely lifted by the center stand, or by the tires... do NOT use the "sears" lift. I guarantee it will damage important parts under the "ol girl"... I have lifted LT's by other parts using an "engine lift" as well, and that requires careful "harnessing" to perform.
A couple of folks on the site really like the "Harbor Freight" lifts. I chose something that appears more substantial... a "Viking Lift"... much like the lifts you see in dealer service areas... only "negative" is it's "orange/black"...
MikeERideWNC said:
How embarrassing..
You should spray it Blue and white.
or get it painted to match the bike! :cool:
Thanks for all the info....Merry Christmas to all!
Ride Safe!
1 - 9 of 9 Posts
