1 - 9 of 9 Posts
Is there a list of descriptions of the screws holding the Tupperware? I have had mine off several times and am missing a few now.
See the Technical drop link in the upper right. Click to Hall of Wisdom. ALL your questions will be answered
Reactions: gtkoppmann
I would like to order all new screws for all of the tupperware so I can replace them with the proper sized screw. I wonder if anyone has done that before...
Only trouble with that kit is the screws don't have the pointy end the stock ones have. They are a lot harder to start in the female thread.
I'm pretty sure I got a few of these in the wrong places...although I did my best to remember where the longer ones came from as I removed them.
To grind a taper on the end of a regular screw, drill the body diameter thru a small block of metal, hold the screw from rotation with a driver, and approach a grinding wheel holding the metal block, rotating the driver. Grind until the necessary taper is reached and then use a wire wheel to deburr the end of the screw.
Not a big deal.
On my F800GT, it was missing a few when I bought it and I found some stainless steel screws at my local hardware store that worked pretty well and the price was a heck of a lot cheaper than BMW OEM and I didn't have to order them or deal with the dealer.
They were philips head and they did not have the pointed end and the head was bigger than OEM but they did work and no one could see them so I was OK with it. I bought some nylon washers but they were not sized to match the screw so they were a little sloppy but again they worked OK.
I think if I lost one now I would go the same route as long as I couldn't see the screw but for screws that will be seen, I would probably go with OEM.
I guess it depends on how anal we will be with our bike's parts and appearances (OEM, aftermarket, etc..) - we have to draw the line somewhere don't we?:nerd:
1 - 9 of 9 Posts
