Found it - here ya go, I hope. Good luck. Have fun!!Dick said:And some more info from the archives. And if I can find it around here, I have a link to step-by-step removal with pictures.
I notice how you find the pertinent thread so quickly.Dick said:Found it - here ya go, I hope. Good luck. Have fun!!
Sit said:Loren you must not have pets that run around your garage and knock things over when you are working on the bike. I can just see a muffin pan in my garage getting kicked and a thousand screws going everywhere.
Does anyone know where I can find a definitive list of where the different screw lengths should be used when mounting tupperware?Can someone point me to pics or videos of the procedure to remove the tupperware. I can wing it I'm sure but if there are shortcuts or problems I may encounter, I'd like to know.
I personally don't use a list. There are some long holes that need to have the longer screws but I usually start with the short ones and if it looks too short or doesn't go deep enough to bite, I move to a longer screw. Seems to work out well for me with all holes filled and tight.Does anyone know where I can find a definitive list of where the different screw lengths should be used when mounting tupperware?
TIA
Thanks, I didn't look at the template. It lists where long screws are needed.I personally don't use a list. There are some long holes that need to have the longer screws but I usually start with the short ones and if it looks too short or doesn't go deep enough to bite, I move to a longer screw. Seems to work out well for me with all holes filled and tight.
If you need a definitive list, you can check the MAX BMW fiche and see what they specify for each location on the covers. OR you could simply read the 5 year old thread you are posting on to find this template.
http://www.bmwlt.com/forums/k1200lt/57746-k1200-plastic-removal.html#post498818
More information
BMW Luxury Touring Community - Site FAQ: All the Rest
Hope these help.
Some people embed their links in a word like "here" in the middle of a sentence and in scanning threads, it is easy to miss a small blue word. I like to make my linksThanks, I didn't look at the template. It lists where long screws are needed.
