1 - 3 of 3 Posts
When I use the alarm fob to lock all the bags the trunk doesn't lock (06 LT). I end up locking it with the key. Has anyone else had this problem?
Did this just start ocurring? The lock wire connector is right under the passenger seat next to the top case, you might try checking that. Mine had been pinched between the seat and plastic shield under top case, repaired it, and now works.
Kirk
Just noticed it
I am not sure if it just started to be honest. I just started using the locks and noticed it didn't work all the time.
1 - 3 of 3 Posts
