1 - 3 of 3 Posts
I have the flashing brake Hyperlights that were installed on my 05 LT by someone else. On the right side there are three lights that aren't illuminating. I suspect it's a connection problem, and have an email in to the Hyperlight tech support. In the mean time can anyone give any suggestions on what the problem might be, and how to go about checking the connection?
Remove the tail light assy to see if the wire hook-up is in that location. Open both side cases and remove the "silver" long bolts at the rear that hold the light assy in place.
Ohm/volt meter, rubber band to hold the front brake lever enough to keep the brake light on, check it out.
1 - 3 of 3 Posts
