hi a mod i found a year or so ago on the site. it doesn't prevent failures but does let you know very early you have a problem(in your parking stall most likely not half way through a long trip) attached is a picture of the weep hole you drill in the bell housing.
it you find an oil drip on the floor you can see the weep hole when the bike is on the centerstand & does not allow oil to build up in the bell housing and if it leaks buy the smell of what is leaking you can prob, figure out what is leaking(slave/rear engine seal or tranny seal)the fluids all smell different(motor oil/gear oil/hydraulic fluid)
i am not saying it will save your clutch but it might and you will know early
