I am in the middle of chaning the trans fluid. Is there a crush washer or o-ring for the drain plug on the trans? I am not seeing one.
No crush washer on mine....only on the fill plug.
look at the top of the K1200lt form page under Site FAQ and type in the search box:
Where is the transmission drain plug?
It will tell you more about changing your oil
Steve
There is no crush washer on the tranny plug.
No gasket as others have said BUT, keep the mating surfaces and threads clean!
Discussion Starter #7 (Edited)
Got it! It threw me off with all the crush washers and o-rings, that the trans drain didn't have one. All back together and just got back from a test ride. No leaks anywhere. Engine oil, trans oil and final drive all done. Thank you guys!!!
I wondered the same thing when I did my first oil change.
People on this site were kind enough that, unlike the rear end, there wasn't a washer.
Best from Tucson
Bob
