joevano said:
Let me clarify, what, if anything, can I look for on a bike that is for sale to indicate a problem?
Joe,
You'll have to put the bike on the center stand and "crawl" underneath it and look at the slave "cavity area" for a small hole. IF you see one and it is dry, no problem. If you don't see one, then you've got to "ask yourself punk--do you feel lucky--well do-ya".
Mine had 39K and no weep hole. Replaced the slave when drilling my hole at 50K and saw some tranny fluid and it had past the felt barrier on its way to the clutch. No harm no foul and I'm safe.
If you see everything else is OK, i.e., heavy throttle and no slippage and there is no hole, plan on doing the slave thing (and clutch housing hole) and enjoy the ride.
While you're under the bike look for any oil leakage, particularly at the main seal area. This will be a royal Hemorrhoid if it leaks.
Definitely put the bike on the center stand and try to "wiggle" the back wheel 3:00 & 9:00 and 12:00 & 6:00. No movement allowed. You should move the bike. This will give you a feel for the rear drive.
Finally (or initially) maintenance records will let you know a lot.
Good Luck,
