The stock Adventure seat is way to soft for me. After an hour I found myself bouncing off the seat pan, and my passenger sliding into me every time I touched the brakes. I had a Sargent that worked well on my RT, but the Sargent is about an inch lower than the stock seat. No-go for my 34" inseam. After a bunch of looking, I found the LDC seat was the only off-the-shelf seat that was able to maintain the stock height. Their "Standard" seat is the same height as a GS, their "High" seat is about the same in the low setting and touch taller in the high than the Adventure's.
I spoke with Matt at Touratech, who described the LDC as stiff, firm, and flatter than stock. All good things as far as I'm concerned, as I loved the firm Corbin on my Harley. I was also hopeful that it'd solve the issue of me sliding forward. The passenger seat has a defined rise to the front to keep her situated. Both seats have sort of a faux suede surface to help prevent sliding.
I only took a short ride today with the seat all the way up front & rear, but my initial impression is overwhelmingly positive. The foam doesn't compress much at all, so it sits me way up. No more flat-footing the bike. The shape and feel is really good though. I'm assuming the seat will break in after a few hundred miles, but as long as it stays firm it'll stay comfortable.
I added a set of Touratech 30mm bar risers at the same time to help compensate for the height. They compliment the seat nicely.
