I have the topcase sitting on the seat have everything disconnected, except the wires for the passenger headset, I found what appears to be a connection, that appears to be weather proof with some kind of shrink wrap or watertight cover. How is this removed or is there some other place to disconnect it?
ps: I have looked in HOW and found steps in removal but does not include this wire.
That may be the connection to the antenna; I don't remember a shrink wrapped connector for he passenger headset/controls. Follow the wire towards the front of the bike and you should find a connector you can disconnect. Otherwise there shoild be something tucked under the rear seat.
Thanks Dave, the antenna does not attach to the topcase, it is attached below it. I found the front coms connector with a bit of electrical tape around it and it is the same type of connector. So I think I may slice it with the knife.
Yes Raffy, this wire goes to the coms connector for the headset next to the accessory plug on the left side of the topcase looking forward.
