1 - 18 of 18 Posts
I picked up my 02 LT from a great guy on Saturday in Oakland, CA. Thanks Galen! It was raining and the trunk was full of the luggage that came with it. By the time I got around to unloading the trunk at my in-law's, it was dark. so, I really didn't get a good look at the interior. My reading material on the plane back to Dallas was the Lt manuals. There was a reference to storage of the oil filler funnel in a compartment in the trunk. Is there such a compartment. If so, where?
Les
Les
If you open the top case and look directly at the center of the opened top case you'll find a little flap. Pull it towards you, it is hinged with a vanity mirror on the inside and a little storage compartment available for some of those paper funnels (never used one on my LT) and operating manuals and insurance/registration.
Enjoy
yup, the one I broken and posted about a fix. Just a mintue ago.
Les
The paper funnels are not all that great.
My K1200RS also had them under the seat. I would only use them in dire emergency. next time your going past a cheapo automotive shop pick up a oil funnel with a long skinny neck.
Discussion Starter · #6 ·
OK, Thanks. I saw the vanity mirror but, somehow, I was thinking of a regular plastic funnel with a tube attached. I'll get one at an auto parts store.
Les
You may want to consider buying a really cheapo plastic funnel - then head over to your favorite hardware store and buy a two foot length of clear plastic tubing to slip over the end. You can hang the funnel from the right hand grip with a piece of bailing wire, fill her up with oil, and have a cold one at the same time!
Or, for about $6.50, you could get one of these. If the jpeg didn't make it to the post, the pic is of a Redline racing funnel. HTH
-tom
Or - one of these that are available at Wally World. Have volume measurements in both liters and ounces, and with a cut-off to stop flow while adding in the measured amount. Available in the auto section, and you can add a longer length of tubing if needed.
And if you change the fluids in the rear drive, a baby bottle with tip of nipple removed - also has measurements molded in.
BUT: They are GREAT when you are on a long trip, and need to add oil. Use one and throw it away. I have one of the red offset funnels at home that I use in the garage, but I would not want to waste space on the bike to carry a plastic funnel, much less suffer the mess of cleaning it up after use before you put it back in the bike.
Woah, help me out here. There are people posting that the paper funnels are great on long trips to add oil. How much oil should be added? OK, I am new to the LT but in the last 200,000 miles on 8 different bikes I only had to add oil one time on the road and it was because I blew an oil line and dripped over time. Is it a normal thing to have to add oil between changes??
33,000 on my '03 LTE and never added oil after the first 1,500 miles. Two complaints you'll rarely hear about an LT is it uses oil and the horn is wimpy.
Not "normal", but there are some of us who have ridden on LOOOONG trips. :D
Don Arthur, Coni, Edgar, Ken, Tom and Rosie, myself, and a few others. When you ride 6-11,000 miles in just a few days, oil addition may be needed. Especially if you are on an Iron Butt ride and cannot take time to have the oil changed.
ibbones said:
Woah, help me out here. [snip] How much oil should be added?
I added 4 quarts to my '02 on my last looong trip. Then again, I drained as much right before adding it. :D
I've always looked at the paper funnels as a "just in case" type of thing. I really never plan on using mine. I do find it humorous that BMW supplies funnels to add oil...while Harley-D does not.
I agree with that as a "just in case" and they are on the bike. I just got a little scared when it was posted that you have to add. I check when I am out on the road and even check tire pressure but having to add oil should not be a thing to do.
Now, this Iron Butt thing might be a different story. Not a "normal" ride through the park.
Thanks again...
[/QUOTE]
What's even more curious is that bikes with little thirst for oil always seem to have a sight-glass, and the burner/leakers have a dipstick, which is usually in a hard-to-reach place, and gets too hot to touch without gloves.
-tom
IBR# 366
Now there's an understatement. :) Unless you're referring to the National Parks Tour, that is. :D
1 - 18 of 18 Posts
