The Trailblazer will turn it into a running light and also a strobe when you apply the brakes.
I have one of those and it works great. Larry Schumer from this board has also designed one based on the same principle. It can be purchased here http://motogear4you.com/mcart/index.cgi?code=3&cat=6. I have also added an LED strip with its own strobe unit from custom dynamics, which I wired to the brake lights. Now when I brake, the top case running light strobes and then goes solid, and the LED light strip does the same, but at a different rate, making me even more visible.
