1 - 13 of 13 Posts
Hi everyone
Does anyone know or is there any consensus on wether BMW fixed top box latch breaking issues with 2005 and up LT?
Opinions please
Thx in advance Darcy
I think it is known that over time the latch will break if you just close the lid and then push down on the lever. You need to put weight on the lid above the latch and then push down on the lever. I put 200,000 miles on two LTs and never had a problem.
Now the mirror is another story.
Reactions: DanDiver
Short answer is NO, never fixed. The one after market replacement for the latch is no longer being made so if it is broken, find a way to fix it yourself, buy a topcase like it from Ebay or bite the bullet and get a new topcase from the dealer but it is the same as the one that likely broke you are asking about. BMW does not sell latches, only the entire topcase.
Lubricate the metal-to-metal on the latch with an anti seize paste and press down when locking per above.
What's needed is a nylon pin rather than that soft steel one that came with our bikes. It wouldn't take as much to pry it open, but I think it would reduce the friction in the lock. You can get 6 mm nylon rod at McMaster Carr.
Someone ought to take this idea and sell them as a popcorn item ready cut etc. I wouldn't mind.
I read about this issue and I took off one latch pin and ground the other so there is almost no effort to latch it shut or open. I suppose it could be wedged open easier, but anyone that wanted to do that could get in there anyway. I think doing these things will prevent any stress on the metal and it won't break.
I believe the original question relates to the rectangular pot metal locking latch on the back of the top case. The mechanical linkage behind that plate puts force on the top two corners of the plate, which is not as strong as the force created by the leverage from the linkage. The two pins in the lid that the "fingers" of the locking mechanism of the bottom grab as the latch is closed are not the root cause of breakage. In my experience, it's always something preventing the lid from closing completely--your jacket sleeve or lunch box or something. Pressing on the back plate to close will exert more force on the corners of the plate than it can withstand. Making the pins in the top thinner or removing one will not prevent this. Getting in the habit of pressing down on the lid with forearm before pressing latch plate will.
As to fixing the broken plate, it's easy to disassemble that unit, and not so easy to repair it with fiberglass cloth and epoxy. Leaves a little visible bump on the back, but works fine and is much cheaper than replacing the entire top case. [BMW's fix] Don't ask how I know this... :surprise:
I would disagree. Mine was extremely hard to close and open with nothing in it at all putting plenty of pressure on the latch. Now it opens and closes like butter. I bet many latches broke from the stock configuration of too much pressure to do the job. Your mileage may vary.
Some have taken to grinding the clamps so there is not as much pressure on the system. See yellow line indicating where to grind with a Dremel or file. You want to make sure you still have adequate pressure to seal the box so it does not leak in the rain and wind. Pressing down when opening and closing is still always a good idea. The lever is too long for the amount for force placed on the thin pot metal with no additional support.
He beefed up the arm and installed a piece of metal to the opposite end of the lated. E-mail him and he'll send you the pictures. Email me and I'll send you the pictures he sent me or the repair. [email protected]. Very robust improvement.
I did not realize mine had broken until someone pointed out the crack across the top left corner. Removal is tough because the latch is riveted to the case. Be gentle when drilling them out. I used JB Weld and put a nice bead across the back where you cannot see it. Sanded down the front after it cured for a few days. Painted it with flat black spray paint and found some t-nuts that worked to mount it and it looks and works good as new. I now put some downward pressure on the top case when closing or opening the latch.
1 - 13 of 13 Posts
