Banned
BMW may have done some thing right! The GTL owners manual calls for the following tire sizes:
FRONT: 120/ 70 ZR 17
REAR: 190/ 55 ZR 17
That means that we have tire choices! We are no longer stuck with only 1 selection, and the price that Metzler wants to charge. I also like the fact that the rear tire will offer wider contact area. A real WIN! / WIN!
Old Slow Guy in A Fast Car
REAR: 190/ 55 ZR 17
OK we now have a tire thread ...
So what kinda oil are you going to run it it? :rolleyes:
BTW The salesman at my Dealer gets to go to Georgia next month to ride the Gt & the GLT.... I now officially HATE him. :histerica
The LT's rear tire is rated at 936 pounds.
From what I can find, the 190/55's are rated at 853 pounds.
I have a very limited knowledge of tires.
Will they have to manufacture a special load rating tire for the new GTL, or is 853 pound rating enough?
In other words, will the GTL use a standard issue 190/55?
Inquiring minds have to know!
Hey guys,
I'm on my second LT - that's 12 years of riding LT's. I've changed out the tires a few times, and naturally had to purchase the 2 or 3 offerings in the LT's special weight rating. But I've always noticed that the BMW Motorad web site specs the 'tyres' on the LT as the more abundantly found and plentiful ZR. I realize that the ZR rated tires would probably wear faster, gas mileage and service life would deminish. But why does BMW spec them as ZR? When I purchase the bikes new, they have the Metz ME880.
Any thoughts?
[copied from the BMW LT web site spec page]
Engine
Type Water-cooled, 4-stroke in-line four-cylinder, two camshafts, four valves per cylinder
Bore x stroke 70.5 mm x 75 mm
Capacity 1172 cc
Rated output 116hp (85 kW) at 8,000 rpm
Max. torque 86 lb/ft (120 Nm) at 5,250 rpm
Compression ratio 10.8 : 1
Mixture control / engine management Electronic intake pipe injection/BMW engine management, Motronic MA 2.4 with overrun fuel cut-off
Emission control Closed-loop 3-way catalytic converter, emission standard EU-3
Performance / fuel consumption
Maximum speed over 125 mph (200 km/h)
Fuel consumption per 100 km at constant 90 km/h 4.3 l
Fuel consumption per 100 km at constant 120 km/h 5.7 l
Fuel type Unleaded Premium
Electrical system
Alternator three-phase alternator 840 W
Battery 12 V / 19 Ah, maintenance-free
Power transmission
Clutch Single dry plate clutch, hydraulically operated
Gearbox Constant mesh 5-speed gearbox (overdrive) plus additional reversing aid
Drive Shaft drive
Chassis / brakes
Frame Bridge-type frame, cast aluminium, engine with vibration-decoupled mountings
Front wheel location / suspension BMW Motorrad Telelever; stanchion diameter 35 mm, central spring strut
Rear wheel location / suspension Cast aluminium single-sided swing arm with BMW Motorrad Paralever; central spring strut, spring pre-load hydraulically adjustable (continuously variable) at handwheel
Suspension travel front / rear 4.0 inches (102 mm) / 5.1 inches (130 mm)
Wheelbase 64.1 inches (1627 mm)
Castor 4.6 inches (117 mm)
Steering head angle 63.0°
Wheels Cast aluminium
Rim, front 3.50 x 17"
Rim, rear 5.00 x 17"
Tyres, front 120/70 ZR 17
Tyres, rear 160/70 ZR 17
Brake, front Twin disc, floating brake discs, diameter 320 mm, 4-piston fixed calipers
Brake, rear Single disc, floating brake disc, diameter 285 mm, four-piston fixed caliper
ABS Standard equipment: BMW Motorrad Integral ABS (fully integral)
Dimensions / weights
Length 98.5 inches (2502 mm)
Width (incl. mirrors) 42.5 inches (1080 mm)
Height (excl. mirrors) 54.9 inches (1395 mm) (with aerial: 75.4 inches [1915 mm])
Seat height, unladen weight 30.3 inches (770 mm) / 31.5 inches (800 mm)
Inner leg curve, unladen weight 73.2 inches (1860 mm) / 75.6 inches (1920 mm)
Unladen weight, road ready, fully fuelled 1) 853 lbs (387 kg)
Dry weight 2) 761 lbs (345 kg)
Permitted total weight 1,322 lbs (600 kg)
Payload (with standard equipment) 470 lbs (213 kg)
Usable tank volume 6.2 U.S. gallons (24 l)
Reserve 1 U.S. gallon (approx. 4.0 l)
1) According to guideline 93/93/EWG with all fluids, fuelled with at least 90% of usable tank volume
2) Unladen weight without fluids
Let me see if I understand this.
One pays $25-26,000 for a motorcycle and then complains about buying tires?
This hobby we're involved in is an expensive one. Get over it and ride.
I think the OP was happy to have a choice of brands and models; this could also mean lower prices but it wasn't his primary point.
IBR# 366
Agreed. I can find standard 180/55R17 tires for my GT at pretty much any bike shop, but getting the special 160/70R17 tires weight-rated for the LT was always a pain in the ass. Especially after you've picked up a nail in some podunk little town, or you've miscalculated how much tread you have left and are still 800 miles from home . . .
The 190/55R17 tires are a little more rare still, but some shops do carry them. And in a pinch, you could always fit a 180/55 if you need it to get back on the road.
